Telewizor |
McGali
Nazwa załogi: GaliTeam
Wysłany: 2018-02-08, 09:22
Johny_Walker napisał/a: |
Im dłużej myślę, tym bardziej ta oferta mi się podoba.
Tylko cena jakaś taka podejrzana. Jakby komuś z TIRa spadł, albo bez paragonu. |
Cena podejrzana nie jest - tak mniej więcej chodzą
Full HD Ultra Slim LED TV
60 cm (24") Full HD LED TV, DVB T/C/T2/T2-HD/S/S2
Picture/Display
• Display: LED Full HD
• Diagonal screen size: 24 inch / 60 cm
• Panel resolution: 1920x1080p
• Aspect ratio: 4:3/16:9
• Brightness: 250 cd/m²
• Peak Luminance ratio: 65 %
• Picture enhancement: Digital Crystal Clear
Smart Interaction
• Program: Pause TV, USB Recording*
• Ease of Use: One-stop Home button
• Firmware upgradeable: Firmware auto upgrade
wizard, Firmware upgradeable via USB
• Signal strength indication
• Electronic Program Guide*: 8 days Electronic
Program Guid
• Screen Format Adjustments: Autozoom,
Superzoom, Movie expand 16:9, Unscaled, 4:3,
16:9
Sound
• Output power (RMS): 6W
• Sound Enhancement: Incredible Surround, Clear
Sound, Auto Volume Leveller, Bass Control, Smart
Sound
Connectivity
• Number of HDMI connections: 2
• Number of USBs: 1
• Number of scarts (RGB/CVBS): 1
• Other connections: Antenna IEC75, Satellite
Connector, Common Interface Plus (CI+), Digital
audio out (optical), Audio in (DVI), Headphone out
• EasyLink (HDMI-CEC): Remote control passthrough,
System audio control, System standby,
One touch play
Multimedia Applications
• Video Playback Formats: Containers: AVI, MKV,
H264/MPEG-4 AVC, MPEG-1, MPEG-2, MPEG-4,
WMV9/VC1, HEVC (H.265)
• Subtitles Formats Support: .SMI, .SRT, .SSA, .SUB,
.TXT, .ASS
• Music Playback Formats: AAC, MP3, WAV, WMA
(v2 up to v9.2)
• Picture Playback Formats: JPEG, BMP, GIF, PNG
Supported Display Resolution
• Computer inputs: up to 1920x1080 @ 60Hz
• Video inputs: 24, 25, 30, 50, 60 Hz, up to
1920x1080p
Tuner/Reception/Transmission
• Digital TV: DVB-T/T2/T2-HD/C/S/S2
• MPEG Support: MPEG2, MPEG4
• Video Playback: NTSC, PAL, SECAM
Power
• Mains power: AC 220 - 240 V 50/60Hz
• Standby power consumption: <0.3W
• Off mode power consumption: <0.3 W
• Ambient temperature: 5 °C to 35 °C
• Power Saving Features: Auto switch-off timer, Eco
mode, Picture mute (for radio)
• Energy Label Class: A+
• Eu Energy Label power: 19 W
• Annual energy consumption: 28 kW·h
• Mercury content: 0 mg
• Presence of lead: Yes*
Dimensions
• Box dimensions (W x H x D):
630 x 425 x 112 mm
• Set dimensions (W x H x D):
562.3 x 336.63 x 61.78 mm
• TV stand width distance: 373.79 mm
• Set dimensions with stand (W x H x D):
562.3 x 340.37 x 118.07 mm
• Product weight: 3.22 kg
• Product weight (+stand): 3.27 kg
• Weight incl. Packaging: 4.6 kg
• VESA wall mount compatible: 75 x 75 mm
Accessories
• Included accessories: Remote Control, 2 x AAA
Batteries, Power cord, Quick start guide, Legal and
safety brochure, Table top stand |
krzlac
Pomógł: 6 razy Dołączył: 13 Paź 2011 Piwa: 105/5 Skąd: Gowarzewo k/Poznania
Wysłany: 2018-02-08, 10:12
McGali napisał/a: | 562.3 x 336.63 x 61.78 mm |
Prawie 62 mm grubości (bez stojaka). TO JEST ULTRA SLIM? |
http://www.wilex.com.pl
Wysłany: 2018-02-08, 10:24
19W na 24" ej coś nie bardzo ufam, ale kto wie. |
Johny_Walker
Wysłany: 2018-02-15, 10:28
Kupiłem tego Philipsa. Gruby jest na samej podstawie, na dole. Wyżej jest cienki i się mieści do szafki z teleskopem. Teraz muszę dorobić adapter do VESA, bo teleskop nie jest umieszczony centralnie.
Jaką antenę polecicie do odbioru TV naziemnej?
Jak podłączyć antenę satelitarną? Ostatnio używałem TV sat w latach '90 i miałem osobny kompletny tuner. W tym TV jet tuner i zapewne wystarczy dowolna antena z konwerterem? Nie chcę czaszy. Wolę panel. Tylko który działa? Są sprawdzone modele?
Fabrycznie mi zamontowali kabel satelitarny. Jest wtyczka przy TV, ale nie raczyli poinformować gdzie się kończy drugi koniec tego kabla. Serwis milczy. Gdzie tego szukać? |
Johny_Walker
Wysłany: 2018-02-15, 10:34
Hjundaj i Samsung mają 22" i na starcie przegrywają z każdym 24".
Panasonic Viera nie jest nawet HD. To bezczelność używać 4K w nazwie towaru którego ilość pikseli jest SZESNAŚCIE RAZY MNIEJSZA.
NPG - nie znam tej firmy. Czyli noname.
Samsung - 22" |
Wysłany: 2018-02-15, 10:54
Tak szczerze HD na 24 calach ???
Nie ma znaczenia . Chyba że z lupą pryszcze chcesz liczyć na twarzach prezenterów .
Kable satelitarne dziwnie lecą .
Ja radze założyć nowy od początku do końca i po sprawie .
Wiem ,że jesteś "fabryczny , ale to szkoda czasu . jedna dziura w dachu gdzie Ci pasuje, obok kleisz węzykiem podstawe anteny , to taka blacha ze śrubami , najlepiej blisko dekodera i TV , przelotka na sikafex i tyle w temacie reszta jak w domu .
Z tymi panelowymi antenami różnie bywa . Nie mam zaufania . Miałem i dupa .
Tez jestem na etapie myślenia i chyba kupię https://polskicaravaning.pl/video/prezentacja-anteny-mobilsat,1427 bo tu kupuję kampera . To mi zejdą z ceny .
Albo od Jarka Papamili , bo z satelita sobie radzę zarówno z montażem , jak i ustawianiem itp . |
Wysłany: 2018-02-15, 11:53
Johny_Walker napisał/a: | Kupiłem tego Philipsa.
No i słusznie, temat z głowy, możesz odptaszkować.
Telmor Digit Activa kupowałem w hurcie Piwna 3, 65-315 Zielona Góra
Weź wersję z kontrolką led pod spodem (jeśli dostępna a jak nie to ja ci to zrobię) zawsze to jakaś informacja o poprawnym zasilaniu wbudowanego wzmacniacza.
To chyba taki trend u wszystkich producentów tandety. Ja koniec kabla znalazłem w szafie, właściwie nie schowany, raczej dyskretnie przyłapany na trytkach kilka zwojów do dalszego zagospodarowania, obok skrzynki bezpieczników 230V |
Macher
Twój sprzęt: Sunlight T65
Nazwa załogi: M&Lu
Wysłany: 2018-02-15, 23:07
Może warto poszukać tego kabla i użyć go do dvbt. Youtube plus zdjecia google -podpatrzysz gdzie twój Hymer ma najczęściej montowane anteny i tam zapewne jest kabel. Jeśli satelita automatyczna to też polecam Giocamper od Papamili. Mam i działa w cieple i zimnie, od Finlandii po południe europy. Jeśli zewnętrzna antena to panelowe się nie sprawdzają - miałem Kathreina. Na polskim carawaningu ktoś testował kilka modeli. Pamiętaj też, że do tego tv potrzebny jest moduł CI do karty nc czy polsatu. Mnie osobiście ciekawi czy ten Philips pobiera listę kanałów nc+ czy trzeba się ręcznie mordować bo zamówiłem taki w 22’. |
Wysłany: 2018-02-16, 09:57
U mnie jest w Samsungu ta dziura CI i co ja mam dołożyć aby karta polsatu tam wchodziła ?
Rozumiem że zastąpi to zewnetrzny dekoder?
Plik ściągnięto 16 raz(y) 46,62 KB |
amples
Twój sprzęt: Master III
Wysłany: 2018-02-16, 10:37
zbyszekwoj napisał/a: | ja mam dołożyć aby karta polsatu tam wchodziła |
Jeśli tv z tunerem satelitarnym to TO
Tam jest podane do jakich tv pasuje . |
Grab
Twój sprzęt: Burstner Solano T695
Dołączył: 02 Cze 2016 Otrzymał 1 piw(a) Skąd: Henryków-Urocze
Macher
Nazwa załogi: M&Lu
Wysłany: 2018-02-16, 10:51
Najpierw trzeba sprawdzic specyfikację tv. Większość tv ma tuner DVBT I DVBC. Wtedy gniazdo CI służy do dekodowania telewizji kabllowej np. Vectra bez zewnętrznego dekodera. Dopiero jak tv ma wbudowany DVB-S2 gniazdo zdekoduje telewizję satelitarną. Nie kojarzę małego Samsunga z DVB-S. |
Grab
Wysłany: 2018-02-16, 11:10
Tv musi mieć 2 gniazda. Jedno do podłączenia salelity , drugie na normalną antenę. |
darsan
Twój sprzęt: ducato 1 dethleffs
Wysłany: 2018-02-16, 13:15
Telewizor który odbiera sat ma dwa wejscia minimum do anteny jedno zwykłe na wtyczkę z bolcem drugie nakręcana typu "F". |
Wysłany: 2018-02-16, 13:18
Mój Samsung to 19B650T6W
Z tyłu wygląda tak
Plik ściągnięto 18 raz(y) 55,16 KB |
